09.17.2008, 08:24 PM
Originally Posted by sjcrss View Post
Well, after searching all afternoon, I was unable to find a suitable diff replacement to house the 4 spyders, I did however find on the NOVA rc site a aluminum diff cup, which may work, also....Im considering buying a set of hardened diff internals, like hot bodies ect, i may try the set I have sitting in a old ofna dominator diff.......Linc...do you have an rough pics or sketches on what you are trying to do..ie adapter ect.....I may just get the traxxas one...and drop a different set of internals in... any suggestions....I also looked at the bolt pattern of other diffs & the raxxas one, more than likely it only has 2 spyders, much like the nitro versoin...this is due to the bolt location.....
I should have some close to finished pics up in a day or two. I have figured out the bearings, shims and measured all of the various lengths. I need to have the machinist tun the adapter down, bore out the lower gear, and mill that gear to a certain thickness. I have to narrow it slightly, which should not cause any strength issues. I will drop off the parts tomorrow and should have them back friday.
