Bernie Wolfard
Clinically Inane
Bernie Wolfard's Avatar
09.19.2008, 05:45 PM
In addition to what Thomas said above, our HV-ESCS are for 6 to 12s ESCS. If you are planning on using 6s or less and want to use an aircraft ESC our Phoenix 125 will do the same thing at a much more reasonable price. It will also be out of warranty in a car but if that is not an issue, go for it. It will also need a pistix. If you are going to run 12s you will need a motor with less than 1200 Kv.
Bernie
