09.20.2008, 01:09 AM
Originally Posted by phatmonk View Post
Whats the tooth count on the Revo center diff?I have a Slayer and it says its 2nd gear has a 38 tooth.Does that sound right.I would have thought Traxxas would have just used the stock Revo 2 speed and just changed the spurgear.Link is there a way to fit this concept center diff into my Slayer?If so pm me and I can prepay for 1 of them.I assume that the E Revo trans isnt compatible in the Revo?Slayer.And if it did couldnt a guy use it instread of a conversion motormount?Just curious.
Thanks Will
I am not sure if the erevo trans is a direct bolt in, but people have put them in trevos, so it should work the same in the slayer. I cannot belive that traxxas changed the tranny case and the output gears on the slayer... Oh well, I am sure that they will offer a center diff for it. If you really wanted a center diff, swap in a nitro revo tranny and just use the traxxas center diff kit. The just run the 36t spur and a large pinion to take care of the different internal ratio...
