09.20.2008, 08:08 PM
Ok, I see how its looking now....couple of ideas or suggestions possibly....
can you machine adapter to be thinner at the attach point to cup....this can bring the gear closer, also how does the gear attach to it, and the output shafts....I see one side is threaded.....are you going to use a modded stock lower shaft?..all in all...looking good and is a good start....
