Originally Posted by sjcrss
Ok, I see how its looking now....couple of ideas or suggestions possibly....
can you machine adapter to be thinner at the attach point to cup....this can bring the gear closer, also how does the gear attach to it, and the output shafts....I see one side is threaded.....are you going to use a modded stock lower shaft?..all in all...looking good and is a good start....
The lower gear has a .080 think flat area on one end, and I will mount the gear to the adapter thru that. The adapter has to be that thick for the mount screws to have something to screw into. I will use cap head m3x6 screws, just the right length.
