09.20.2008, 08:48 PM
If you just remove the switch and solder the wires together the warranty should be fine. If you fool with the pcb the warranty is usually voided. I would check the switch as it sounds similar to the problem I had and the switch was the culprit. A better toggle switch would be a great idea.
