GO-RIDE.com
09.21.2008, 12:14 AM
Originally Posted by Bronco View Post
Since my rear diff was leaking, I decided to change the diff oil in all 3 diffs.
I'm going for 1K rear, 3K center and 3K front.
When I did the center and reassembled, I could hardly move the diff when holding both ends.
Is 3k too heavy or is there a problem. I reassembled it like said in the manual.
Lots of crt.5 guys run 3/3/1. There should be resistance, but not so stiff that it barely moves. Sounds like you have a mechanical issue. I've run as thick as 7000 in the center diff and it did not sound that stiff.
E-8ight - Tekin RX8 2000kv/4S
