Gee
A Horse's Ass
Gee's Avatar
09.21.2008, 07:39 AM
Sorry jnev, I remember posted a reply right after your post. I probably switched IE tabs and didn’t hit the post button. I’ve pulled that one before. I am using some older 14mm hexes I had. I was told they were made by Hotbodies but don’t know for sure. I drilled them out ¾ of the way to get them to fit correctly. I like them due to they have a place for a rubber ring to go on them and hold the hex pin in.
Thunderbruiser you are right I am upgrading the rtr to the st-rr specs and the center "rear" driveshaft was added due to the extended chassis I added. But not everything else is from the rtr.....
The rock guards and chassis braces are from the st-rr. The screws are from Tonys and the bearings are from fullforce RC. The battery tray and top deck are from my garage. The motor mount and pinion are from RCM. The rear 16mm big bores shocks are from OFNA. The big bore springs are from Kyosho. The tires and wheels are from Traxxas. The servo is (Hitec 5998TG) from Servocity. The common sense BEC, Spektrum DX3R and SR3001 Pro receiver are from a lhs called B&B hobbie. The MM and 1515 1y motor are obviously not from the rtr. I do have other parts but haven't installed them yet. Shock towers, wing mount and some front 16mm Kyosho big bores coming in the mail. All from the st-rr. But other then that, everything else if from the rtr.....
