xcntrk
xcntrk's Avatar
09.21.2008, 08:49 AM
Looking good!
Hopefully you have better handling luck then I have. I’m already down the road of full swaybars, changed spring out, etc, I hope that does the trick. Also as an FYI; the stock Slayer tranny comes with the “wide-ratio – 38/18” gear set as standard. So combined with the 36t spur and you’ll be running stock gearing.
What kv is a 13L? I’m guessing somewhere between 11L~14L puts it around 1950kv? On 5s you’ll be turning about 600rpm more then me and combined with 20t spur = you’ll be flying! My Slayer was uncontrollable geared for slower then this. I wish you luck and look forward to your feedback about this rig.
Tmaxx BL Conversion
Hyper-7 Truggy
E-Slayer
