What do you do about the holes in the Medusa's can though? I got a 50mm Medusa for my Rustler and I need to cover the holes up to keep the dirt out.
http://http://www.impaktrc.com/produ...oducts_id=3076
Use this to help you choose the right KV rating on your motor, it's got basically everything you need to know in it. I have the Tekno RC 1.5D and used to run it in an E-Revo and it ran like a scalded dog but it's an amp hog and thus drains your lipos faster and heats up faster than a lower KV setup. I plan to take the 1.5D and put it in an Ofna Hyper for street use, then get a 2.5D and run it on 5s/6s lipo and 7s A123. You have to aim for a KV that'll be battery-friendly as well as not heat up too badly but you also have to keep the weight of the batteries in mind, a 10S setup is probably not going to work too well in an E-Revo
