Thread: MMM Mods
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
09.22.2008, 12:26 AM
That's a nice case mod!!!!
thanks!
Originally Posted by DRIFT_BUGGY View Post
Would it be possible just to put 4 little round foam (or whatever them are) things inside the bottom of the case? 1 at each corner to stop the bottom from hitting or will that make the fan sit up more?
Ill try to find what I am talking about and post it up
I dont think it would effect the fan at all, but I also dont think it will help...
as you can see in those two pics, the board is supposto sit on top of the tabs on the case bottom...
because of the design, the board does not sit right. I dont think the best answer is cramming more (o-rings/foam/etc.) under the board because the clearance issue still exists. This is why I removed the sponge that castle put in there. and cut the hole for the board to sit flush.
For me...the castle sponge fix didnt really make sense.
Its as if I had shoes that were too small and started getting blisters...and instead of getting different shoes, I put on a second pair of socks. The shoes are still too tight, but now they are even tighter than before. It just didnt add up. I donno, maybe I missed something
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
