Thread: MMM Mods
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
09.22.2008, 01:13 AM
Originally Posted by CRTIM View Post
would it be possible to build up those 4 corners up with something (glueing some plastic or even hot glue ) so the board would sit up further and not wobble ?? and would the case still fit ??...or is it just as easy to cut out the bottom of the case ...thanks for the help
I felt the case was a tight fit with just the foam pad...
...When I first got the replacement ESC, i removed the sticker and took a look inside. When I went to snap the case back together, the bottom seemed to be a bit warped when doing so. ....It kinda fought me. Id get one side lined up, and the other required some persuasion(more than I was comfortable with being such a small board)
It was then that I decided to do the mod.
Once I dremeled out a hole in the bottom, it didnt seem to require any force to get the case closed. It snapped shut like it was meant to.
*edit* to answer your question....I suppose its possible, but I didnt try. I believe less is more (so to speak) in this case
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
