Sammus
Sammus's Avatar
09.24.2008, 07:25 PM
Could be a solder connection on the motor side...maybe? Like if something came loose then that third pole wouldnt be energized and it would kinda be trying to keep the rotor locked in one position. then if the joint was bumped back into place it would function normally again...
not likely, but worth checking i think
