Thread: Ubec / Evx
GriffinRU
10.31.2005, 11:15 PM
Can you take the two main wires on the evx and wire them more like the brushless systems. Just run the wire from the dean connector on one to the dean on the other. Then wire the ubec up to that.
You can do that, but I won't recommend due to the fact that front end of built-in BEC will be floating in that configuration and might create some problems.
But with 2 battery packs connection should look like the picture.
Artur
P.S. In general you can just pull red wire out of EVX 3-pin connector and use any external source for receiver and servos without interfering with EVX.
Name:	ubec & bec.jpg
