Originally Posted by cheesecake
i use the zippy lipos there a bit wide but if you shave the tray a bit they fir just fine. i run a 5s setup
I saw your buggy build that u used mike's tray, are u still use it. Thanks for the info, but i will be using the RCPD one which is about the same dimension as mikes, but i don't know if it is as easy to shave down as mike's.
