brushlessboy16
brushlessboy16's Avatar
09.27.2008, 02:02 PM
Just a little bit on out outside edge of the cup to make the ring gear fit over it. I actually think I just did it with some sandpaper. It didnt take much at all.
I have a brand new Kyosho center dif here with a 50T gear on it. (It think its a kyosho anyway) Not sure where I got it but it doesnt look like it has ever been used and I have no use for it at this point. PM me if you want it. Not sure if a 50T will work for you or not. But it should drop right into the cen if I rmember right. I'll let you have it very reasonably if you can use it.
hmmm makes it alot easier and give me more room for gearing, i think ill take it :D
Century make a 9t pinion, but only good for a plastic spur.
what happens if i use metal to metal?
i know that duratrax makes a spiral cut gearset for the raze (very stong i know from expireince) that might fit for diffs
