09.28.2008, 11:27 PM
whew, rough night but im back.
I think im going to have a shot at fabricating my own components.
motor mount will be out of 2x2x 1/8th aluminum angle, and battery tray will be from 1/8th kydex plastic, going to try to make a die out of wood to use as a form.
and use another peice of wood as the die to form it.
is aluminum sturdy enough to tap into, or should i use a nut and bolt
1/8 al is a bit thin. Go up to 1/4 or 5-6mm. Then you can drill and tap the edges. Kydex makes great trays. I like to use the velcro strap and cut slots in the sides to thread it thru.
