JThiessen
JThiessen's Avatar
09.29.2008, 09:30 AM
by hand
You need to figure out how to square it up too. If by chance you get a piece of AL Ang extrusion that is actually 90degrees, box it up, and bury it in the yard, cause its worth its weight in gold! Most of the time, the angle is less than 90, so you can shim under one edge to get it sit square. Best method is to find a piece that has been machined square.
