sikeston34m
sikeston34m's Avatar
09.30.2008, 11:30 AM
Hey Truck,
Thanks. Mind if I join in on this conversation? I'll tell you about what I learned concerning various componants with this setup.
It's looking GREAT so far.
I see you chose the 4120/18. Great motor! I was running the 4120/14 using the 4.3:1 truggy gears along with the 5.75 Revo tires. I seen this setup running 60 - 65mph on 6S Lipo 10C! I know the batteries were being pushed over their limits. They got very warm.
This is where I ran into a problem. When you blow the inboard rear diff bearing on the pinion, go with the 3.3:1 buggy gears. They are MUCH tougher. I know, I know. It's a taller gear ratio. But the pinion does NOT have spiral cut teeth. The spiral cut pinion side loads the pinion bearing. It's not a thrust bearing, so it just doesn't hold up.
I blew mine on the 2nd run. I replaced the bearings with Ceramic Nitride versions. Same result. It punches the center bearing race right out. Then you have balls everywhere. LOL
It was at this point, I decided to do a custom Wye wind on a 4130 motor. 7 strands of 22 awg for 4 turns IIRC.
I felt like I had to do something because with the 5.75" Revo tires, the gearing was too high for the 4120/14.
Using 5.75" tires.
4.3:1 gears equals 4.2" of rollout per motor revolution.
3.3:1 gears equals 5.5" of rollout per motor revolution.
HUGE gearing change! So I decided I needed the added torque of the custom wind along with the longer stator.
The end result was incredible. BUT.........there's always a but. LOL
The starting amperage of the new combination was so high, during the last half of the charge, it was lazy out of the hole and the batteries were getting really warm. This time I had 5000mah 20C and they should be good for 100 amps continous with 125 amp Bursts. I'm not sure if this was to blame on my custom wind or not.
With the 4.3:1 gears it worked perfect with the 4120/14.
Traxxas has came out with the Slash! I've been looking at those tires. They are EXACTLY what this setup needs. Now let's plug some numbers.
Using 4.3" tires.
3.3:1 gears equals 4.1" of rollout per motor revolution!
Even better than the 4.3:1 gears using the 5.75" tires.
I'm Glad I didn't sell my converted Revo stuff after getting disappointed and sidetracked. I will revisit this project. All I need are some good Slash Tires/Wheels.
