Thread: Wiring
Papa
Papa's Avatar
11.02.2005, 08:45 AM
I am getting a small order together of different pieces and parts.In My cart are the Gmaxx extension, and a couple of 3.5mm plugs.
1: It sounds like I ought to add the UBEC? Is that a good idea?
2: I need some 4mm pinions. I'll get a range of 3 to get the gearing right. Where should I start?
3:I need a couple of fans. Mike can you add one for the heatsink motormount, and one or two for the controler. What do you think is best?
4: Mike, If you have a UE titanium center shaft for the exteded chassis, I'll take one.
Any thing else?
Should I order through the store? There are a couple of things not in the store. Do you think I'll get a PM from Mike to go over things? :C:
