10.01.2008, 10:43 AM
Yeah, but Arct1k is using a Neu 1515, which is about 44mm in diameter, while the motor in the pic above is probably the typical 36mm.
How about removing the front brace and using a custom piece of aluminum between the center diff and front diff? Should allow room for the motor. Then, you have have to remove the brake, or use a thick plate (spacer) between the motor and mount to allow room for the brake parts...
