I know people here like to modify thing around here, but wouldn't it be easier to just use the EVX the way it is supposed to be used? A good high torque servo can't be that expensive
For the same reason you upgrade plastic parts to metal :)
And you can run at higher voltage... (more power)!
Digging up an old topic for sure!!
but tell me, why do you think that there is no 14.4 volts on the novak?
I was talking about 3-pin connector.
Artur
