10.03.2008, 06:03 PM
Originally Posted by phatmonk View Post
So if the Gorilla Max fits a Revo will it work for a Slayer?
It uses the same front end rear ends basically except for shorter suspension arms and push rods, so in theory it should fit just fine. My only thought is that the G3r chassis is too long, but you can still find the chassis without the extended rear upper and lower plates, that would keep the proportions correct for the slayer...
