e-mikey
10.03.2008, 07:32 PM
Originally Posted by pullinteef View Post
Also, the wires are normally super stiff under the shrink tubing because the wires are the motor windings, possibly to be confused with over solder soaked flexible wire. As someone else said, unless you removed all the insulation how can you tell how far it's tinned?
You can tell by trying to bend the wire, they are definitely tinned more than 3/4 of the wire No need for me to remove the heat shrink this time, it's obvious.
I just find it weird. Both my medusas and my 8xl just had the tips tinned. I'm sure there is a reason.
