good work Neil, i thought once you had the steel idler in there you would be set, never seen that before.
As for the RC4wd gears, they're aluminium arent they? If they're not hardened steel i don't know how they would hold up against the hardened steel idler. I know the ULTRAMAXXED gears were 7075 aluminium, but used brass (i think it was) idlers
