brushlessboy16
brushlessboy16's Avatar
10.04.2008, 04:17 PM
Originally Posted by blueb8llz View Post
ok so im back to report my results. sorry for the long delay. i ve been super busy, plus my truck was outta commision so i wasnt able to run my maxx till recently.
all i can say is thank you cool runnings! hahah. you werent lying, the fan made a huge impact. from taking breaks every 15 mins or so, to taking no breaks at all! through the entire run of pretty hard bashing, my max motor temp was only 141 degrees with outside temps of 70. that is insane!
my lipos were 108, and mmm v1 was at 101 degrees. another thing i noticed was i had a little more runtime. i guess when things are cooler, you get more runtime? not im contemplating if i should gear up since i have the option now. but im already geared pretty high..24/68. most people with a 7xl gear it 20/68. my max speed was 44.7mph, but it usually runs around 42mph.
so in conclusion, it drop my temps from 150 degrees just after 15 mins of bashing to
140 degrees throught the entire battery.
you will get longer runtimes, less power is wasted in the form of heat.
