TDC57
TDC57's Avatar
10.04.2008, 05:22 PM
Thanks for the comments guys..
I’ve got questions paintball questions
• Can you please look at these shoots and then try your best to answer the following questions:
• Will this bottle setup work ??, I basically removed everything down to as far as it goes and I'm doing a direct connect now.
• Do I need to worry about any air reducers, diaphragm or what not’s ??
• Where can I buy this small black house ?? if I extend it will have a negative effect one the gun ??
• I'm thinking about just permanently locking the trigger switch on the main circuit board and running the it’s power supply to my 3rd channel on my RX (that way in theory) I just need to hit my 3rd switch and it goes live and starts shooting (???)
• let’s talk hopers shall we.. Do I want to use just a gravity feed one or the one I have ?
• I’ve gone to several paint stores but I couldn’t find a smaller one (is there on
• out that holds like 50-75 shoots in lue of 200 ??
• will my 9mm bottle get things cold with this setup (?) if so what insulation should I use to protect what little hose I have
• Any ideas on what to use the cover / protect the curict board, you’ll notice that I have elevated above the Truggy drivetrain so I'm good there but I need to cover / protect the boards from dirt and bashing..
More questions to come.. Thanks in advance for your time..
Shaun.
Dry fit in the Truggy.. Dam this fits great!!!
Look at the clearance I have, but how do cover / protect the board
Ok this is basicly where I whant it, I just need to extend the small black hose (bottle to gun / curict board) but can I, and where can I get the hose ???
Last questions. Will I ever get rid of my headache (ooooowwwwww) my head still hurts from all the K1..
Nothing!.. Hahahahaaa..
