mohanjude
Need for speed
mohanjude's Avatar
10.05.2008, 01:45 AM
I purchased several hundred dollars worth of connectors and cables from this company. They ship from China using regular airmail and it can take weeks to receive the orders. Some items are shipped in several packages and arrive piecemeal. However so far they have sent everything I ordered. There is a Bidproduct forum where you can get support - the company does appear to fullfill all the orders even if they are missing / faulty.
The motor in question looks exactly like a hacker once it is mounted on the truck. There is a difference - the end bell is screwed in but looks different to the Hacker when held side by side. Otherwise external construction wise it is hard to say it is not a Hacker - the colour, fins and shaft look good.
In operation it does the job. I realise that it is cheap imitation but for $46.00 you get what you pay for. If it was my one and only motor purchase I would not buy this motor but to try it out - I didn't think it was a bad purchase. If you dont push your truck to the limits and want to experiment with a Basic brushless setup on a stock truck I think this motor will work for you. A New motor will give you much pleassure but then it is 5 times more expensive.
I personally like to push the setups I have and therefore prefer Lehner, Neu or Plettenberg BL motors. I would put this motor in the same category as a Feigao - good value for money and a real Blast while it lasts.
