Thread: 12020 Question
squeeforever
squeeforever's Avatar
11.03.2005, 11:09 PM
it doesnt matter what color it is. its just typically red + and black -. it doesnt have to be black. also, just run the red wires to the positve terminal of the deans and then the black wires to another deans; just the negative...duh. and the run a jumper from the first deans to the second. on will be positive and the other side will be negative. no, its not to have to solder it if you have at least soldered before. i would recommend practicing. also, just use some standard shrinksleeve.
