brushlessboy16
brushlessboy16's Avatar
10.07.2008, 10:37 AM
Your heat source is to close to the plastic - gradually heat it up along the bend line in multiple passes.
No need for water cooling - this is likely to make the plastic brittle - Just hold in position whilst it cools - should be only 30 secs...
Remember you will need to overbend slightly as it will spring back.
oh, ok. that was my suspicion- do you think that my methods affected it?
its 3/16-pretty thick.
