10.07.2008, 09:59 PM
Make sure none of the cells have puffed. Also check individual cell voltages thru the balance port. If they are wildly off you may consider charging the cells individually thru the balance port.
I would suggest a low charge rate, .5 amp max. If you can get the cell voltages over 3v each you should be fine. Be careful.
I have successfully resurected cells that were below 1 volt. Took a while.
What brand is it?
Also, set the MM lvc manually, I do not trust the auto lipo setting. Make sure your setting refelects 3.1-3.2v per cell.
