joeling
joeling's Avatar
10.07.2008, 10:26 PM
Hi RBMike,
Originally Posted by RBMike View Post
I have 2 working V2's still. The one with the most hours on it (several weekend worth) is one that the fan connector broke off of the first day. I cut the "grill" section out above the fan so the blades could not catch on it & wired the fan to the RX. This V2 has performed flawlessly since I did the mods after the first day. My set-up is 5S, Neu 1512 3d/f,RC8 18/46 gear. The other one only has a couple of hours on it. It still is using the stock fan & connector but I cut the grill out of it. I also carved some clearance in the case around the connector & but I'm thinking of busting the connector off the board on purpose. On both V2's I have put shrink tubing on the big plug sockets to keep them from shorting on the heat sink. I did have 2 earlier V2's fail but they were not modified (failed on the same set-up).
It's good to hear that the V2 are starting to become more stable like what u have. Personally, I think the MMM is a solid controller let down by some auxiliary bits. However, those bits are user repairable.
On with the torture...I mean testing
Regards,
Joe Ling
Hyper 9e Medusa 4S, Savage 5S MMM 8XL, Jammin' 4S Neu MMM, X2 Ninja JX, X2 MMM 5S Neu, E REVO Medusa 6S
