hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
10.10.2008, 01:49 AM
how do i cut the switch and hot wire it?
cut the switch off the end of the wires. expose the wires and twist them together. The ESC turns on and off when you plug and unplug the batts at that point.
all a switch does is connect and disconnect the two wires that run to it.
*edit* dont forget to heatshrink any exposed wire
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
