stum
10.10.2008, 07:20 AM
Originally Posted by Gee View Post
Drift_Buggy did the mount you have your MMM on come with the kit? Any problems with clearance when the body it on? I need to come up with something different for my 8ight. The body sits right on top of the fan I have on my mm. From the first picture in your thread it doesn't look to have too much of a bend more like an angle down towards the chassis. Is that right? Thanks.
I used my dremel tool and cut that 'esc stand' stand down basically in half. I used the current wire routing notches as the new height and trimmed it all the way around at that height. Then I made a few more custom notches on my lowered plate and also flattened the three screw downs for the personal transponder on the bottom side and I just used some 3m heavy duty two-way tape to hold the transponder in place. PERFECT FIT!
