crazyjr
crazyjr's Avatar
10.13.2008, 10:27 PM
I would adjust the punch control maybe 40 percent or to a degree where you do not get wheelspin.. then i would drop down a few teeth on the pinion and drop my timing down.. Combonation between puch and gearing will bring down the amp spike a good bit, and the timing will keep motor temps down... less wasted heat means more power and runtime..
I never use the punch control, did once, thought i had a bad motor after a while. I know use the epa on the transmitter now
