rchippie
rchippie's Avatar
10.14.2008, 09:09 PM
Not required for stopping the end bell from falling off like a Feigao and temps should be ok.
However it would help with stopping dirt from getting into the open end and would provide extra surface area for heat dissipation.
I run an S HS on my 50mm & mike ran a L on his 60mm - The XL would fit the 70mm perfectly with a neu front cover or be slightly too long 4mm without - Or you could use an L HS and have 10mm uncovered.
or you could just use a clip-on if required. Lots of options.
Well this well be on road so im not to sure there will be much if any dirt . I like the HS idea just not sure if the end plate is needed for on road .
REAL MEN RUN BRUSHLESS
