10.19.2008, 03:48 PM
Looks like you killed the little roll-pin that holds the input gear onto the shaft; I did that recently too. You can just use a hex key and grind it down to size (diameter and length wise) for use as a stronger replacement. Use a little JBWeld or Epoxy to secure it in place and bob's your uncle.
