10.20.2008, 10:54 AM
Originally Posted by rchippie View Post
James that gear would be the easyest to use since there would be no modding needed . I was just trying to use the stock ratio if possible .
That is the gear I use on my gtp with the kb45 motor. I have not had any issues with it so far. I do not like steel spurs due to the noise, and the only 6mm bore pinions I found were not hardened, so I had to use a plastic spur.
