rchippie
rchippie's Avatar
10.20.2008, 10:58 AM
That is the gear I use on my gtp with the kb45 motor. I have not had any issues with it so far. I do not like steel spurs due to the noise, and the only 6mm bore pinions I found were not hardened, so I had to use a plastic spur.
Thats the reason i want to use the plastic spur because of the noise .
REAL MEN RUN BRUSHLESS
