Originally Posted by BrianG
I really liked both of my Quarks (one sold with my Revo). Always VERY smooth no matter how slow you go. Even with the newer MM/MMM firmware, I still think Quark is smoother. Quarks simply operate differently in their start up routines than the MM/MMM. If you can get by the heat and warranty issues, and run 5s or lower, it is a good ESC. Personally, the thermal mod is needed though - the pad they use just isn't good enough for proper heat transfer. Adding a couple caps helps even more.
I have been having success with my quark on 6s, but I have a spare MMM that I will use from now on. Quark has lost (or the korean postal system) 3 of my escs, so I may do the mods and just run them till they crap out. I want to do a custom case with a real heat sink epoxied to the fets. My only issue is that the program buttom is on the wrong side... I will figure something out...
