RUSTY XL-5
RUSTY XL-5's Avatar
10.20.2008, 11:53 PM
Not sure I know the answer to what temp to low is.. but I do know that if you are running a pack that is cold... 50 degrees F outside and the pack is at air temp it has noticeably less punch. The internal resistance goes up the lower the temp which makes it less capable of delivering current effectivly lowering it true C rating at the lower temps. I tend to be on the safe side. What I have found to be a good solution in the colder months when I want ot run is a couple of those hand warmer bags (the ones when you break the seal inside they heat up for an hour or 2.) I toss a couple of those in a small cooler and keep the lipos inside there untill I'm ready to use them.
I thought they would slow up when cold, and thanks for the cooler idea. I'll be using that idea this winter.
PS. I would really love to know (if somebody does) what is too cold for a lipo. That way I can leave them in my tent (protected of course) and not have to worry about warming them up until it is time to use them.
I will spank a nitro any day...guaranteed. :)
