Originally Posted by E-Revonut
While your ordering if you are converting to 17mm at the same time order yourself some extra 17mm nuts!
+1 on that.. and if you are running on concrete or ashpalt, just order another set of adapters as well. A nut WILL come off.. and that end up putting the treaded adapter spinning on the surface.. Bye Bye threads.
