CRTIM
10.21.2008, 09:53 PM
Originally Posted by MetalMan View Post
I think centered is a better choice, so you can keep your overall CG as close to the middle as possible, and better balance out your right and left sides.
yeah ,that was my initial thinking, beings that the motor weight is in the right rear and the servo and rx is in the right front....the MMM will be in the center rear off the center diff mount...i was thinking the battery weight would be best in the left rear or middle...
so would the best set up be equal balance from the center ??....LOL..or am i overthinking this whole weight balance issue ??
...edit...wow,i just went and set all my components as they would be mounted on the chassis....and picked it up by a wire hooked to the center diff...no matter what, the battery side is gonna be MUCH heavier....didn't realize it would be that much heavier on the battery side(using a 5s 5000 or 4800 mah @ about 600g)
