A4DTM
11.08.2005, 09:55 AM
updated.
http://s93886278.onlinehome.us/sv/in...=BLMT2_Renders
switched the C50XL for a Feigao 540C L..
http://s93886278.onlinehome.us/sv/BL...der47540cL.jpg
not completely done, but one more solidworks session and it should be ready to have the test parts cut, to make sure everything works how it should.. the main structure is done. just little detailing left, and one more small piece that will connect the rear diff. case to the rear brace...
also added a little more bracing on the top deck, as it holds the battery holders in place, so I can't allow for any weak points.
alot of friends see the pics and say "you should do this for a living".. so any rc companies need a modeler/designer? :)
