Originally Posted by strodedawg
here is my set-up (batts on the way)
rc8 w/ rc-m conversion
medusa 36-60-2000
mmmv1 with 10+ races on it
zippy-r 5s 4800s
how are some of you calculating estimated run time
it is geared for around 34mph using speed calculator
any help would be appreciated
here is a vidoe of my caster fusion also
http://vimeo.com/1915910
That setup should get you around 20+ minutes of race time. A 1512 3d on 5s 5000 can run for about 25 minutes. The Neu doesn't pull as many amps as the Medusa, but you have a pretty efficient setup.
