stampedeproject
stampedeproject's Avatar
10.23.2008, 02:33 PM
Looks good - be great if it could be marked out so nothing overlapping and holes for the screws to cross pieces marked.
Then one could just tape to lexan and cut...
Might be worth reaching out to TCS as they have some cheap lexan cutouts for the upper link fill in's $3 - They could probably make these pretty cheap...
More commision for you...
PS how many AX10's did you buy or did you get sponsored?
I didn't have the CAD files for the cross spacers so I will need to measure those later.... and yes that would be the way to go to just tape and go. My thought was that you need to print two copies anyway for the left and right body panels, and since you only need one hood and roof panel you could just use the hood panel from copy one and roof panel from copy number two.
I have five AX10's at this point and, I think, eleven crawlers at this point. Axial has been good to provide a couple units for articles. Generally by the time they send a new one, the other one looks so bad that it's time for a new one anyway. I generally end up replacing links and tranny cases to get extra photographic mileage out of the chassis before everything completely wears out and that of course in on my dime.
