Source for 5mm bore 48P pinions?
skellyo
skellyo's Avatar
Source for 5mm bore 48P pinions? - 10.23.2008, 04:57 PM
I have only found one source for this style pinion, Kershaw Designs. Their price is quite high at $20ea. Does anyone have another source?
The other option I'm contemplating is buying a pinion from sdp-si that has a bore of about 4.75mm and just hitting it with a 5mm bit on my drill press.
Any info on if someone has done this sort of thing would be appreciated.
Also, FWIW, this is to install a 1509/1Y into a T4 that is going to be converted into a J82. I plan to run 2S primarily, but probably will hit it with 3S for some speed runs or stupid fast bashing.
