Dragonfueled
Nore more bump boxes and after run oil
10.23.2008, 05:04 PM
Originally Posted by E-fanatic View Post
The ones for the xxx-t were sealed with a rubber gasket?
So were these and were very smooth. After two races they were very gritty and after that they started failing.
Bernie I know what you ment I just hear allot of people say that if xxx motor is geared to low it will run hot. Maybe its a myth ... Also about timing , Medusa says run there motors at 8-15 for best effiency. Should we still run those on 0?
Brushless ..... I put that s... In everything.
