CRTIM
10.24.2008, 03:26 PM
would this be a good choice for a CRT truggy/ Neu 1515 2.5d/MMM mainly just for racing ,not too much bashing or speed runs
thanks for the help
trying to decide between the Neu,or the Zippy's ,which are cheaper but heavier and bigger then the Neu's ...so i don't mind spending the money if in the long run i will be buying a better quality and performance battery....Thanks guys
NeuEnergy 5S-1P 5000 Car [4]$246.00 $184.50
* 5000 mAh capacity. Special shape to fit in RC cars.
* 125A continuous, 250A short duration
* Low resistance cells for higher current and less heating
* Balancing taps for safety and convenience (fits Astro Blinky)
* Heavy gauge wire with Deans compatible connector
#Series
#Parallel
Volts
L (mm)
W (mm)
H (mm)
Weight (g)
51
18.5
142
47
35
626
