Pdelcast
Pdelcast's Avatar
10.24.2008, 05:23 PM
Originally Posted by Dagger Thrasher View Post
It sounds to me like the fan control must've partly been a hardware addition, otherwise V1s would have had it when running the same firmware. IMO, it's no big deal; I guess there's a *slightly* higher chance of a fan faliure with a V1, but at the same time, it should keep things a tad cooler too. Doesn't bother me.
We had to add a transistor to allow the processor to control the fan -- but the temperature at which the fan turns on is controlled directly by software.
It is set at about 150 degrees F, which is about 65C. The hardware is good to about 120C, so the fan comes on WAY before the temperature limits on the controller are hit.
Patrick del Castillo
President, Principle Engineer
